UC-540 Wireless signal issues
Brook Powers
We replaced our Cisco 877W with a brand new UC-540 from Cisco in January 2010.
We setup the UC-540 via wizard. Upon use,  we immediately noticed a decrease in wireless signal strength and dropped connections every three minutes or so - even when within feet of the device when compared to the Cisco 877W.
We first attributed the issue to the slightly more enclosed mounting location, or the additional metal shelving. . We were just about to pay for a professional site survey to rule out radio interference when we discovered a a reference from http://uc500.com/en/uc520w-built-wifi-fluctuating-rf-levels.
We decided with Cisco's STAC to test the following solution before RMA'ing the unit as faulty;
antenna receive right
antenna transmit right
It worked! Our signal strength is much better and we have yet to drop a connection after two weeks of regular use.
Did Cisco fail to consider that there is only one antenna in this device?
26 Replies 26
David Hornstein
Level 7
Level 7
Excellent stuff  Brook,
Thank you very much for this input and bringing this to the attention of the wider public, your comments are indeed accurate and relevant.
I looked up this issue and found this issue mentioned in an release note regarding CCA version 2.
see reference:
http://www.ciscosystems.cd/en/US/docs/net_mgmt/cisco_configuration_assistant/version2_0/release/notes/OL159332.html
It mentions an issue discovered and CSCtg07290 workaround;
CSCtg07290
CCA should set antenna TX/RX to right (primary) under dot11 radio interface on UC 520 and UC 540 platforms with integrated wireless
Symptom Poor audio and dropped calls for wireless phones connected via the integrated wireless access point on the UC 520.
Workaround The only workaround for this issue is to access the device CLI and configure the "right" setting under the dot11 radio interface for both transmit and receive.
UC520(config-if)#antenna ?
   gain        Configure Resultant Antenna Gain
   receive    receive antenna setting
   transmit  transmit antenna setting
UC520(config-if)#antenna receive ?
   diversity  antenna diversity
   left          antenna left/secondary
   right        antenna right/primary
regards Dave
Thanks, Dave.
Hi Brooke,
Found this one out the hard way, good o'l Dave Harper pointed this out to me after a week and a half of torment with one client... I am so glad you posted this as I totally forgot to
I am not sure why a dipole chipset was put in one of these boxes although they only carry one antenna, pity there is no way to add the secondary antenna and use the chipset to their full advantage.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Ugh. I had to reset my UC-540 and now I cant find my way to Dot11Radio Interface again.
The following is useless to me as far as assisting in the configuration of the device;
Would someone mind providing the correct commands starting after logging into the device via telnet.
Hi Brooke,
You need to go to the interface to do it, please see below:
ROUTER#(config)#interface Dot11Radio0/5/0
ROUTER#(config-if)#antenna receive ?
ROUTER#(config-if)#antenna receive left..errrr or is it right MEH! i forgot LOL
Have a go at that.
Cheers,
David.
Everything is tied to the right amtenna on my UC540. I was doing;
and
ROUTER#(config)#interface Dot11Radio1
but getting no where.
For other resons I reset the device to defaults and its working fine. It must have been an upgrade along the way that set the antenna's back to diversity.
That just goes to show you that upgrades sometimes have no respect for your existing configuration and if you dont have a need for the fixes upgrades provide, the upgrade may make things worse.
Thanks David!
Hi Brooke,
I'm a sucker for new upgrades, it gets me into a lot of trouble, I call it the Homer Simpson syndrome, I keep going back for more even after I have burnt myself.
Cheers,
David.
Well, resetting it to factory defaults did not, in fact resolve the random drops and waves of poor signal strength.
The problems reared their head after just a few days.
Here is what I just tried, based on David Trad's advice;
ROUTER#config
This returns the current (and factory default) settings, below
If I type;
ROUTER#(config-if)#antenna receive right
Sets receive to the right antenna - the only one physically present
ROUTER#(config-if)#antenna transmit right
Sets transmit to the right antenna - the only one physically present
And run
or
ROUTER#(config-if)#antenna transmit ?
I get;
NOTHING has changed.
What am I missing?
Is there something to do with the diversity command?
Hi Brooke,
What am I missing?
These may be stupid questions but I think we need to start somewhere
  • Is the appliance housed inside a cabinet?
  • Is the appliance surrounded by a lot of electrical devices/cables? (Within close proximity)
  • Is there a lot of other Wireless access points in the vicinity (Within a 50-100 Meter radius?)
  • Is the Appliance set as WPA?
  • Have you changed the channel it is using? I.E tried another channel other then the auto scan? (Look at forcing it onto channels 6 or 11 for testing)
I have one UC-500 deployed right now where we have had to force it onto one particular channel, it would not work on any other due to congestion in the area, even still it is not stable as much as what an 877W would be or an 1141, but it is doing the job just (and for now).
You can also consider the following:
  • Purchasing a Cisco approved wireless antenna that has a higher DB rating (So long as it is not illegal in your area)
  • Disbanding the inbuilt wireless and purchasing a 11XX AP which in any event would be much more powerful/stable over a UC-500
Might not be the best of options, and also the most simplisic questions, but it would be a good place to start in my mind.
Cheers,
David.
David,
Thanks as always for your reply.
  • The unit is in the same location it was when STAC made the changes to the antenna that caused the unit to work much better.
    The unit is still surrounded by the same CAT5e and power cables, but not too many.
    Yes, there are a lot of WAPS in the building, but still the unit worked well after the changes made by Cisco's STAC to use the right antenna.
    The appliance is stll set to WPA2.
    The channel was 8 before, and it is 8 now. I may try setting it to "least congested at startup", but I remain convinced the issue is due to the factory default settings configuration, which assumes a right and left antenna. There is no left antenna.
    I wish I could remember what else the Cisco STAC did, because it made the wireless work very well. This time I will record/document the session and when/if it works, post it back here.
    Maybe Cisco STAC has a record of the session?
    If you have the case #, I will look it up for you.
    Thanks Steve!
    It was one of these three. Most likely Case# 613652985 or 614554143.
    CASE HISTORY
    CASE                               ISSUE        CISCO STAC REP
    Case # 613652985         7975G Firmware upgrade woes                        Derrick
    Case# 614554143          7975G VPN Client "This key not active here"   ?
    Case#  614554255         Multiple Gateway IP’s how to in CLI?               Jason
    "                                     Single Number Reach being wonky                  "
    Case# 614605353          Wireless sucks again after reset to defaults   Jason
    There is no relevant data in any of these opened from your site.....
    But Case=614605353 has **no** data, looks like they are waiting to hear back from you????
    Maybe it was discussed and not documented.
    Sorry ;-)
    Message was edited by: Steve DiStefano
    I found something...
    A different case from a different site....
    "try manually setting the antenna tx and rx to right instead of diversity"
    F340.02.18-UC520W-2(config-if)#antenna ?
    F340.02.18-UC520W-2(config-if)#antenna receive ?
    "We have made the changes to both the TX and RX.  Great news... this has
    fixed our issue..  Thanks for your help
    Seems like antenna is set by default to diversity.
    provided instructions to set the antenna tx/rx to right (primary)"
