04-02-2013 11:40 AM - edited 03-21-2019 07:11 AM
Is there an option of full time call recording function on a UC560 system.
Chaudhry
04-02-2013 02:48 PM
Yes with optional, expensive recording applications. You can search the forum for more information.
04-02-2013 02:56 PM
04-08-2013 08:18 AM
You should also consider TantaComm's Capture Lite solution. Big time savings compared to other solutions as you only need to license for concurrent agents and not the traditional license per agent model. Can offer on-premise, SaaS, cloud, so lots of options to fit your budget.
04-13-2013 10:47 PM
Chaudhry,
I have personally used Callrex. It's well worth the money.
It's really not hard to justify the costs if you need the product. We have set it up for financial services firm, and it has been well worth the purchase.
Thanks!
Chris
04-16-2013 07:09 AM
Chris,
I am looking to implement the Callrex solution at one of our customer sites. This customer has a UC560 and two UC540's can you tell me if you can do Forked Audio witht he UC5XX platform? I know how to set it up in CUCM, but not quite sure if it is possible for the UC.
Stewart
04-16-2013 01:24 PM
Hi Stewart,
To the best of my knowledge, no. I have been using span ports.
It looks like if you were using the 1800 or 1900 as a cube, that would be possible.
Thanks!
Chris
