UC 560 FXO
Hi, I'm new here. I have UC 560 FXO, 2 Cisco 2900 Router,2  Cisco Catalyst 3560 V2 series PoE-48 and 4 tel Cisco 7942. I want to create a VoIP network from point A to point B ; where I can find all settings, connections and configuration commands for these?
Thank you,
Adrian.
2 Accepted Solutions
johschaf
Level 4
Level 4
Cisco Configuration Assitant Admin Guide(this will be for the UC): http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_2_1/administration_guide/cca_sbcs_admin_guide.pdf
Cisco IOS CLI for Initial Configuration(for 2900 series router)
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/appendixAcli_external_docbase_0900e4b1810581a6_4container_external_docbase_0900e4b181547f63.html
3560 Configuration Guides(find the one that matches your IOS)
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_installation_and_configuration_guides_list.html
Please note, the UC will be the voice gateway, so you would only really need the 2900 series routers for internet/LAN routing, not voice. You will want to configure the UC and 3560 connection as an 802.1q trunk, tagging the voice vlan. For access ports on the 3560 make sure you have the following command for the phones: switchport voice vlan 100
-john
I would certainly think so. You just need a route on the 3560s to the network at point B.
-john
7 Replies 7
johschaf
Level 4
Level 4
-john
thanks for your response; actually, between point A and point B I have a Over The Air bridged IP traffic provided by 2 RF 7800 M MP Harris Multiband Radios ( an IP Network between each other); in this case, I still need 2900 ?
Adi.
I'm not very familiar with the point to point wireless bridges you have. What function are the 2900s serving? If they are just acting as layer 3 gateways, then I would think the 3560s could do that function.
How To Configure InterVLAN Routing on Layer 3 Switches
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
-john
in this case, if the 3560s do that function, can I connect to 3560 a PC for data exchange with another PC on point B?
Adi.
-john
thank you very much for your support. Maybe if I stiil need help, you can help me again.
Adrian.
dragan_adrian_remus@yahoo.com
I have this situation now: in point A, I have UC 560, switch 3560 v2 PoE 48, 2 Cisco Ip phones ; in point B, I have switch 3560 v2 PoE 48, 2 Cisco Ip phones. All equipment is configured and functional; the switches are connected through straight cable, between fa 0/2. Vlan's are configured too; interface fa 0/2 (3560) trunked.
Instead of connecting cable, I'll have a radionetwork. The ends of this radionet are in different subnets, but one are the same with one 3560(the one connected with UC 560). So, I'll need to interpose two 2901. Please tell me the settings for these routers.
Adrian
