UC 560 Incoming call
yency
Hello
I wonder how do I configure an PSTN incoming call for an extention in the UC to foward that call to the reception number, but ONLY the PSTN calls?
paolo bevilacqua
What do you mean?
Calls from PSTN all go to reception.
Any other call go to the number called.
That is normal when you only have analog lines and no DID service.
Hello
Thanks for your answer
Is when someone call an extention from PSTN, that call has to be foward to the reception, but only pstn calls, but internal call should go normal to the extention.
ephone-dn XXX
no forward local-calls
Note
1. I'm not 100% sure if it will work for calls that are not coming in straight via DID number.
2. I don't know, and I don't comment, if it is doable with CCA.
