Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1464
Highlighted
Beginner
UC 560 - Prompt Management Voice Mail
I have a new installation of a UC560. It is using the aa_sbcs_v03.aef script in Auto Attendant.
Currently, when a user dials an extension if it is not picked up it will go to voicemail. My client would like the option of letting the caller dial "0" or another extension rather than leave a voicemail. I have "0" setup as a blast group. Can this be done in CCA or is some other  custom scripting method needed? If it is a custom script, how would I go about creating it? An example script with the  above option would be appreciated.
Everyone's tags (4)
3 REPLIES 3
Highlighted
Enthusiast
Re: UC 560 - Prompt Management Voice Mail
In the CUE GUI, you can change the input settings to allow 0
to go to a certain extension.
That being said,  It is not supported in CCA.
Adam Compton
Highlighted
We have a similar issue is there a example of a script available?
Highlighted
Enthusiast
Georgios,
There is not a "script" that you need.  You just need to modify the settings for the caller input on the users Voicemail box.  This can only be done through the CUE web interface.
Thank you,
Darren
