02-13-2012 01:16 AM - edited 03-21-2019 05:20 AM
I currently run a UC320 routing both voice and data, with a simple ADSL modem ahead of it - all runs well, with the exception of all too frequent disconnects on the ADSL modem.
So I'm considering a SRP547W to replace the ADSL modem. If I use an SRP547 as the ADSL modem and main router for both ethernet and wireless data access, can I then use the ethernet ports on the UC320 as a basic switch? I don't need anything fancy and I've not looked into the detail yet, I'm just looking for a quick confirmation whether it would be possible?
Clive
02-14-2012 01:17 AM
Hi Clive;
Perfectly possible, setup would be as following:
Internet -> SRP500 -> UC3000 -> Phones + PCs connected to a switch.
Alberto
03-19-2012 10:56 AM
OK, I'm about to purchase a new SRP547W to accompany my existing UC320W. Am I correct in thinking that I've seen mentioned somewhere, that there is a tech document that details using the UC320W with an SRP500 series router/modem?
If so, then can someone please send me a copy - note I'm not a Cisco Partner, just the end user who purchases the hardware and maintains it myself, so please don't send links to documents that I cannot get!
Thanks in advance.
Clive
