05-30-2011 10:54 PM - edited 03-21-2019 04:10 AM
I am trying to configure UC320 to use access code 9 for dialing out but i could only see 9 + 7 digit and 9+10 digit as dial pattern.
Is this customizable?
What i am trying to achieve is 9+ 7 digit and 9 + any digit going out to FXO trunks. Is their something like 9.! or 9.T on UC320?
Thanks in advance!
05-31-2011 05:45 AM
For US Region, UC320W Configuration Utility allows you to select either 7 digit or 10 digit dial plan. That should be the only thing you need to configure ... all the rest is handled automatically and is not customizable. The default configuration should meet all your North American Numbering Plan needs ... 7 digit, 10 digit, 11 digit, n11, operator, international access code etc. If you have specific needs beyond that please communicate them by opening up a case with the Small Business Support Center.
Jeff
05-31-2011 06:31 PM
Hi Jeff,
This is for Philippines' dialing plan, anyway do you know how to open up a case with the Small Business Support Center.
Rick
