07-23-2012 09:26 AM - edited 03-21-2019 06:04 AM
Hello guys,
I have a UC320 running 2.1.4 and am having trouble with the hold music. I have tried two seperate DVD/CD Players and no matter what cd or player I use the sound is VERY disroted. There is no way to adjust the volume/gain coming out of the devices, and the sound is normal on headphones or through an amp.
I cant find a way to adjust the volume of the music on the UC320 (is there even one?). It basically sounds like its up to high..
What is my next step?
07-23-2012 10:38 AM
Hi Erik,
I helped a similar customer with volume with Music on hold.. In that case though the volume was too low and a PMF was created to increase the gain level.
I can do a similar PMF file to reduce the gain level and have you try it out for noticeable improvement.
Can you email me at rbordner@cisco.com and I will work with you.
Randy
07-23-2012 03:15 PM
Erik,
One additional check for audio quality and volume is to dial the external Music source from a registered phone:
From a phone(example SPA50x)
-> Setup -> (1)Directory -> (3) Corporate Directory -> (1) Internal Directory -> browse to ExternalMusic xmusic -> press dial soft button. This will connect you to music source.
Can you also lower the volume of your external music source connected to UC320W?
08-13-2012 12:41 AM
Hi their are you able to send me the PMF to lower the volume?
08-13-2012 07:56 AM
Jack, Please emial me at rbordner@cisco.com and I will provide you the PMF. If the PMF works for you I will release the PMF for publishing to the community.
regards,
Randy
