A customer of mine needs to change the system default audio message of its VM. Is it possible?
I am not referring to the Welcome message, but the message that tells the caller to speak after the beep.
Giuseppe
Hi Giuseppe,
You can press the envelop button or dial into mailbox pilot number to get into mailbox voicemail menu, press 4 for setup menu. You can delete old voicemail greeting and add a new one.
Best regards,
Wendy
I have this problem too. A customer wants to disable the system greeting which is played after the user recorded greeting.
Any chance?
Alfred
With AA if you record all the prompts as user prompts there is no system default greeting - Are you talking about voicemail?
I'm speaking of voicemail.
User records his personal greetings (busy and unavailable). If somone gets to the voicemailbox the personal greeting is played, afterwards there is a system message telling the caller to leave a message after the beep.
I want to disable the system message since the user already tells the caller in the personal greeting to leave a message.
Hi Alfred,
Sorry, the system message which prompt user to leave the message after the tone can't be deleted. It's the current design.
Best regards,
Wendy
Hi Wendy,
thanks for your answer - is it possible to put it on a feature request list?!
Kind regards,
Alfred
Hi Alfred,
Sorry, we don't have plan to change this design in the near future.
Best regards,
Wendy
