Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
488
Beginner
UC320W - Doesn´t send ext. as CLID
Hi all,
maybe somebody can help me. I installed a UC320W. Only a SIP Trunk is used as line.
Everything works fine except CLID
If you call outside, on the called phone only the no. without ext. is showed.
SIP provider checked his logfiles - he receives only no without extension.
I am useing PBX mode - but I tried mixed also.
Please help.
Best regards
Marcus Plessl
Everyone's tags (5)
2 REPLIES 2
Frequent Contributor
Hi Marcus,
Do you have the DIDs configured for each Extension on the Inbound Routes page like this? (Click image to enlarge)
Chris
Beginner
Hi Chris,
No, I had no route for each extension. I only had one incoming route which lead to a collect extension (0)
Now I tried as suggested inbound routing like you can see in picture.
Unfortunately then this extensions are not able to call outbound any longer.
If I try I get busy signal instant.
Also I noticed that Inbound Routing leads to every call is going to collect extesion 0 even if it is dialed ext. 13 for example which is not in collect ext.
Best regards
Marcus
