10-14-2011 08:31 AM - edited 03-21-2019 04:48 AM
Hi All,
I have just turned on my UC320W and the power, LAN and WAN lights just keeps flashing green. Does anybody know what could be up with it ?
Josh
10-14-2011 10:13 AM
Hi Joshua,
Is your UC320W able to give you DHCP address? Does it respond to ping?
Try power cycle first, if this does not help, proceed to perform a factory default, then load a saved configuration or site_backup.
If unit still does not respond to any of these, I suggest to quickly call in the Small Business Support Center for further troubleshooting.
Their phone number is: 1-866-606-1866.
The following page contains the pertinent contact list.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cheers,
Julio
10-17-2012 03:05 PM
Hi Josh ,
were you able to have this issue fixed i am currently facing the same issue and the system was in operation , any help will be greatly appreciated thanks again
Regards ,
Chris H
