UC320W pwd reset
ausarkan
unfortunately I forgot the pwd, how can I reset the pwd or make a factory reset of the box?
many thanks in advance
August
Hi August,
On the left side panel of the unit is a reset button.  If you press and hold for 20 seconds, this will perform a factory reset of the unit.  Once the unit is back up log in as cisco/cisco and set the password.  You can then load a saved configuration that you have saved to your PC.  If you had the automated site backup saved to USB key, a quick call into the SBCS center and they can help you extract a saved configuration from the USB backup.
Chris
