440
Highlighted
Beginner
UC320W stuck in firmware update
I'm working with a new client that has an existing UC320W. When I first attempted to login, I learned about the incompatability of their current firmware with newer versions of Flash. I downgraded my laptop's Flash and was able to login. I was immediately prompted to update the firmware.
The system told me it was a two part process. The first part seems to have run fine, but when the second part of the upgrade begins it shows the attached screen.
This screen continues after "downloading" for about 16 hours. It also puts out phones in an unusable state.
Is there a way I can escape from the "automated" process and update the firmware manually with a downloaded copy of the fw file? I attempted to reboot the router, but as soon as I logged back in it immediately returned me to this process.
I made the mistake of launching this process without a backup. Any advice you can offer is greatly appreciated.
2 REPLIES 2
Highlighted
Beginner
I downloaded the firmware update to my laptop, and powered off and on the router. On logging into the router, I glimpsed a message in the top right corner, something to the effect of "Update from my computer." I selected this and was able to successfully update the router. Problem is resolved.
Highlighted
Good save!  Glad to know there was a solution!
