UC320W WAN port unreachable
obencandemir
Hi all,
I am a new Cisco enthusiast and presently an end user. I have embarked on a learning adventure with networking and jumped in with both feet.
I have the following hardware:
Cisco 887VA Integrated Services Router
Cisco ES520 series 8 port switch
Cisco UC320W appliance (of course)
I had the router as part of my existing data network and so I followed the Greyfield Smart Design guidelines for voice only service.
I have selected this topology and have my connections as per the guidelines.
Summary:
Cisco 887VA (fast ethernet port 3) ---- VLAN 4 ----- (WAN port) UC320W
I have configured the 887 with the IP address 192.168.2.253 with mask 255.255.255.252 on vlan4.
On the WAN page of the UC320W I have configured it with IP address 192.168.2.254 and mask 255.255.255.252. I have set the gateway as 192.168.2.253. My DNS servers etc are from the ISP.
My router config for the setup is:
interface FastEthernet3
switchport access vlan 4
switchport mode trunk
no ip address
interface Vlan4
ip address 192.168.2.253 255.255.255.252
ip nat inside
ip virtual-reassembly in
ip nat inside source static tcp 192.168.2.254 8080 interface Dialer0 8080
Now when I try to ping the UC320W from the router I get no response:
cisco#ping 192.168.2.254
Sending 5, 100-byte ICMP Echos to 192.168.2.254, timeout is 2 seconds:
Success rate is 0 percent (0/5)
and from the PING tool in the UC320W web interface the same:
PING 192.168.2.253 (192.168.2.253): 32 data bytes
From 192.168.2.253 icmp_seq=0 timed out
From 192.168.2.253 icmp_seq=2 timed out
From 192.168.2.253 icmp_seq=3 timed out
--- 192.168.2.253 ping statistics ---
6 packets transmitted, 0 packets received, 100% packet loss
I cannot access the WAN port from anywhere.
What am I doing wrong? Any suggestions? Please feel free to make any or ask any further questions.
Matthew Needs
Hi Ben,
First of all, there is a PMF file to allow ping on the UC's WAN port.. It's blocked by the UC's firewall by default.
https://supportforums.cisco.com/docs/DOC-16301
Try setting your Fa3 port to access.. It's a trunk at the moment. You're config is a little mixed up.
switchport mode access
FYI - If you need a port to be a trunk in the future with a different native VLAN(default is 1). Here is how you would do it..
switchport trunk native vlan 4
Finally, double check your UC's remote access port is actually 8080 and that remote access is enabled through the GUI.
Hope it helps
Matt
Matthew Needs
Hi Ben,
Hope it helps
Matt
Hi Matthew,
Thank you for your response.
I made the changes and applied the PMF. I can now ping the UC320W successfully from my router and other computers in the network.
I can also access the configuration from the WAN port now also which I couldn't before the ping started working. That remains a little mysterious as I would have thought the appliance would have responded despite filtering the pings.
Anyhow it all works now so I'm very pleased.
I could make and receive calls before by the way; but the lack of a response was disturbing; even though the WAN status was showing received and transmitted packets.
Thank you again.
Glad to help. Have fun!
Matt
