UC500 8.6 Bug - Auto Attendant Issue
josh.fontenot
Beginner
Beginner
I am unable to create a sub-menu within an AA script using the CUE web GUI.
2 REPLIES 2
David Trad
Rising star
Rising star
Hi Josh,
Have you checked to see if CCA the latest version supports this type of setup yet? The CUE web GUI as I understand it, is slowly getting phased out, or getting cut down a little.
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I don't use CCA because in the past I find that I am limited to what I can and can't configure.  I may give CCA a try the next time I deploy a UC500 and see if this fixes the AA submenu issue I previously had.
