04-28-2011 05:48 AM - edited 03-21-2019 04:01 AM
We have a client interested in the SBCS, but all the computers in their office are Macs. I'm wanting to know if there are ways to run software such as IP Communicator and Unified CallConnector other than a virtual Windows machine through parallels.
Derek Graham
Tech II Business Services
Saratoga Springs NY
04-28-2011 05:15 PM
For now, CCA, CIPC and Call Connector will need to run on Parallels or VM Ware. I would use Parallels because VM Ware has an issue where you can't use the built-in microphone for CIPC.
04-29-2011 04:30 AM
ok, thank you.
04-30-2011 11:29 AM
Just an fyi - CIPC is not supported in a virtualized environment. It works and you can make calls, so it fairs well in a lab environment, but I would not recommend this solution for a production network.
Cole
05-02-2011 05:34 AM
ok, appricate the heads up. Always good to set the expection "hey this works however..."
