UC500 and Stonefax
jcartier
Beginner
Beginner
Hi All,
I'm having an issue where I'm trying to setup StoneFax into our existing enviroment and its not taking to it at all...
The StoneFax system guide, I feel, is rather light on setup examples.  It does give an example of the following...
voice service voip
fax protocol t38 fallback pass-through g711alaw
dial-peer voice 1 voip
description INCOMING FAX FROM PSTN TO STONEFAX
destination-pattern 4..
session target ipv4:10.10.10.1
session protocol sipv2
codec g711alaw
no vad
I've followed this example to no avail.  My question is, if I have a DID that I want to map to my fax # how do I go about doing so?
I created another dial-peer and used the incoming number and a voice translation profile to map it to a 4xx number; but that didn't work.
Does anyone have any experience setting up stonefax?
3 REPLIES 3
Marcos Hernandez
Collaborator
Collaborator
The dial peer that you need to create is a POTS one. Did you do this?
I think I've finally got it all worked out :)
Report back in a little bit
The last note here was that you think you got it fixed.  I am having an issue setting a test environment for this with using SIP.  The dial-peer seems to be working fine as I can send faxes out, but I can't receive it.
Can you tell me what you did to fix it so I can test on my side.
Thanks!
Chris
