UC500 - Configuring fax to have "call-forward busy" behavior
jeremyneedle
This particular customer receives a LOT of incoming faxes. As such they have 2 fax machines: primary and secondary.
As it stands now, incoming faxes all go to the primary fax. However I want to add a configuration, such that, if a busy signal is detected, the UC can automatically forward this to the secondary fax machine
This seems easy to do w/ an ephone-dn config...is there a way to associate that w/ a pots dial-peer? I feel like I'm missing part of the big picture
Can someone point me in the right direction?
2 Accepted Solutions
dial-peer voice 5500 pots
destination-pattern 333
port 0/0/0
dial-peer voice 5501 pots
port 0/0/1
preference 1
Marcos
aaronc123
I don't think that you can do this with CCA ... but you could to try something like this:
dial-peer voice 20001 pots
destination-pattern 1001
preference 1
no huntstop
port 1/0/1
dial-peer voice 20002 pots
preference 2
no huntstop
port 1/0/2
1) incoming call matches extension 1001
2) Two matches exist ... pick preference 1
3) Ring -> Busy
4) No huntstop, so keep trying
5) ring preference 2
That said ... I don't have time to mock this up in the lab untill tomorrow ...
port 0/0/0
port 0/0/1
preference 1
Marcos
aaronc123
preference 1
no huntstop
port 1/0/1
preference 2
no huntstop
port 1/0/2
3) Ring -> Busy
jeremyneedle
Thanks guys! This took care of it.
