UC500 Fax Detect and send call to fax extension
m.castrigno
Beginner
Beginner
I want to to be able to detect a fax call that has come in on a pots line that configured to go to AA. While the prompt is being played without delay I want the fax tone detected and the call sent to the fax extension.
I have read this fine document:
https://supportforums.cisco.com/docs/DOC-9713
But it wants to store the fax as an email. I don't have an SMTP server that will work the UC500 and I do not have a PC running all the time that can use the SMTP server noted in the above document. I simply want to be able to use one pots line for incoming voice and fax. I don't want the user to have to press a button. Just dial the PSTN number and hit send their fax machine and it shows up on my fax machine.
Thank you.
0 Replies 0
