07-06-2011 11:11 AM - edited 03-21-2019 04:19 AM
We are fairly new to the UC500 product. Can anyone give me an idea of the UC500 fax capabilites? We are specifically looking for fax to email capability for users with a dedicated fax DID. Not sure if the UC can do this or not.
Thanks!
07-06-2011 11:20 AM
invechnologies,
T37 Fax to e-mail is fully supported in CCA 3.01 and you should have no issues getting it to work, the SBSC can help with the configuration.
Have a great day
07-06-2011 11:22 AM
Hi Sir,
Only adding to Arthur answer.
In the link below you can find the appropiate guide to do that.
https://supportforums.cisco.com/docs/DOC-9718
Regards.
Andrey Cassemiro.
