UC500 - Inbound FXO Call Block Example?
nyciscotech
Anyone have a working CLI example of blocking an inbound FXO call based on Caller-ID?   The UC540 was configured with the default CCA config and unfortunately not having much luck getting Call Reject to work from the command line.
Thanks!
mcasimirc63
Level 4
Level 4
It is not possible even if you use CLI.
https://supportforums.cisco.com/message/3090662#3090662
Any truth in the above post or does using CCA for the config disable this functionality?
You can block calls if they use a dial-peer for incoming calls (i.e...SIP Trunks or PRI).  FXO ports use a connection PLAR command which forwards the number without the use of a dial-peer.
