UC500 integration with Truckmate
skavlekar
Beginner
Beginner
I have a customer that is using Truckmate, produced by a company called TMW. Has anyone done integration of this software with the UC560 as the customer wants to integrate their database.
thank you,
sanjit
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
In practice, what is that your customer wants ?
Hi Paolo,
The customer is looking at the UC560 solution. They have a database of their customers on the Truckmate solution. When a call comes in, they want the calling number to pull up their customer information on the screen from their truckmate solution. Is this possible with the UC500 ?
thanks very much,
You have to ask the software vendor about witch protocol they interface the phones system, for example TAPI, that is supported by the UC500. If they just want to launce a web page based on calling number, you can also use the TAPI Web Launcher that I wrote and can be acquired from my website - mentioned in my profile.
Note unless you have previous experience with telephony and networking, it is recommended that you engange a certified Cisco partner, or person with equivalente knowledge and expereince, for both the pre-sale and deployment of the product.
Paolo,
Thanks very much. I'll check with the vendor. Yes, it would only be carried out by a certified partner, if it is a workable solution.
thanks again.
Recognize Your Peers
