07-05-2012 04:49 PM - edited 03-21-2019 06:00 AM
Hello everyone,
I have an UC500 that is working great on a LAN, CIPC and physical handset, no problems.
My goal is to relocate the UC500 to another office that has of course another subnet. There is a vpn link connecting the two sites.
I did it, I had to change the ip address of the UC500 reflecting the new subnet, from the orinal LAN I can ping both the new ip address and the service engine no problem, but the phones got stuck on registering. From the UC500 I can ping as well everything. There are no polocies in the tunnell, everything is allowed.
I also change the source-address statement in the telephony-service section.
Any ideas?
thanks
07-05-2012 05:03 PM
we recommend to use CCA to configure UC500 platform to avoid any configuration errors and it is easy to operate. you can start from scratch for new setup in new site.
thanks
07-05-2012 05:05 PM
Thanks...but i d avoid to reconfigure 50 phones, all rules and everthing...it is just a change of ip i guess it shouldnt be that complicated...
thanks
07-05-2012 05:13 PM
i understand , please try this
1.
telephony-service
create cnf
and reset phone.
2. reset the switch after save confgiuration confirm.
if you still see the issue, please attach the show run after remove any private.
thanks
07-05-2012 05:20 PM
thanks for the answer. I had to roll back as the third party didnt provide E1 connection to the new location, so I cant try in real time unfortunately.
From phone prospective, what exactly a phone is looking for to be registered given that it can reach to UC500? I mean, what step would you do if you had to reip a uc500? What i did:
- change ip on vlan1
- reconfigure routing (and confirmed through ping).
- change source address in telephony service to reflect vlan1
is that it? should it work after this or you need to do something else?
cheers
07-05-2012 05:30 PM
i never even try change the ip addres manually, things on top of my head, DHCP, Static routes, Firewall/Access-list.
and one thing, why did you change the souce-address under telephony-service, that is vlan100 ip address by default.
thanks
07-08-2012 04:39 PM
any thoughts from anyone else?
thanks
07-08-2012 06:11 PM
If you are using CCA earlier than version 3.2, you may run into this bug :-
CSCtr47098 All phones failed to register when VLAN100 IP address changed via the CCA
07-08-2012 06:19 PM
Hi Jon,
thanks. I didn't reconfigure the ip throught CCA, I did it through command line, details:
- changed ip on vlan 1
- changed source address (currently binded to vlan 1 no 100, and everything is working)
The CIPC are on Vlan 1 as they are running on pc that are on vlan 1. Once i moved the UC500 on the new location, changed ip, changing routing and verified that the pc was able to reach the new site and the UC500 with the new ip, I fired up CICP on the same client I ve verified connectivity, but it was stuck on registering. I brought back the UC500, changed the ip back and it worked again.
So i m thinking that something else must be done.
thanks
07-09-2012 05:47 PM
any clues anyone?
thanks
nick
07-09-2012 06:04 PM
could you send me your configuration file to my cisco email.
thanks
07-09-2012 06:32 PM
You will also want to make sure that the DHCP pool is modified to reflect the network change. Make sure that option 150 points to the correct ip address.
Brandon
07-09-2012 06:46 PM
thanks. DHCP is provided by a Windows server and option 150 reflects the new ip. BTW i m using CIPC at the moment, so no really need for option 150.
Bongsu, thanks mate, but i m not authorized to post or send configurations file.
Let me try this way: what is needed for a CIPC to be registerd to a UC500?
Also, what i didnt do, after changing the ip of the uc500 and the thelephony service statement, i didnt do a restart with the new settings (this to avoid to restore previous conf). This is definitely something i ll do.
thanks
07-09-2012 06:46 PM
What is the the model of the phone?
- As a process of elimination, have you tried erasing the IPV4/Network/TFTP/ configutation setting on one phone, then reboot the phone .
If that does not work, I will delete CTL file file, this of course should reboot the phone.
- Thanks.
07-09-2012 06:51 PM
Hi Kelly,
95% of users are using CIPC not physical phones, and not even with CICP I could make them register (the only thing i could see is updated time/date and "registering" message there forever). Tried from the same host to ping everything (new vlan ip, service engine and everything) and it wa sjust fine, so the routing is not the problem. Also the tunnel is full opened, no restrictions whatsover.
I guess there is just a stupid conf line that i have to update that i m missing. Also I didnt restart the router after changing vlan1 ip and source address in telephony service, but i m not sure if it is required.
thanks
