I would like to restrict outgoing calls for a certain user to a list of numbers that I create.
Solved! Go to Solution.
you can use class of restriction (COR) list through CLI.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Hi Bongsu
I did use them and they worked. It would be nice however if I could restrict calls to a list of numbers and not have to make a dial-peer for each number.
As alternative to COR, you will need a custom TCL/IVR script to do that.
