08-07-2012 06:10 AM - edited 03-21-2019 06:07 AM
Good afternoon,
Could somebody tell me if wireless phones 7925 are compatible with uc520? Do I need to have a special version o CME? i've read somewhere that the uc520 also supports the Cisco 521 Wireless Express Access Point. Can somebody tell me if uc520 works with other type of access points (ex: Access point 1250)?
Thanks a lot for your help
Best Regards
Solved! Go to Solution.
08-07-2012 06:41 AM
Yes, these are supported.
You can use any AP you want, preferably Cisco.
08-07-2012 06:41 AM
08-07-2012 07:47 AM
Hi Paolo!
Thanks a lot for your answer. just one question: Do I need to have a special version o CME for working with the phones 7925? i think our client got cme 4.1.
Thanks one more time
Best Regards
08-07-2012 07:48 AM
Please use latest version.
Thank you for the nice rating and good luck!
