Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
840
Beginner
UC520 8.6 bind commands breaking MWI
As some of you may know, software pack UC520 8.6 adds 2 bind lines in the config -
voice service voip
sip
  bind media source-interface Vlan100
  bind control source-interface Vlan100
These above lines are required to register SIP based phones such as 9971 or Iphones.   Unfortunately having these lines in the config also causes MWI to stop working.
What is a standard setup/config to have both SIP phones registered and MWI working simultaneous?
Thanks in advance
Everyone's tags (4)
4 REPLIES 4
the issue will be next CCA 3.2.2,
for now, you can just remove these 2 lines, this is for remote teleworker access only, and 9971 not support remote teleworker with UC500. other thank this everything will be fine include MWI.
after remove, dont forget
vocie register global
create profile
then phone will be reset.
Beginner
Bongsu,
Are you saying SIP phones such as 9971 do not depend on those 2 lines for it to work?  So I can remove the two bind lines and get a 9971 or Iphone working?
yes, correct
