UC520 8.6 & Jabber problem
jyoopro4ia
I'm having problems trying to get Cisco Jabber 8.6.5 registered on our UC520.
I used the CCA to add a new Cisco IOS device and in the Jabber configuration screen, I cannot get past the window requesting for SIP digest authentication info.  I keep getting "invalid credentials".
I am currently connected to voice vlan via wireless.
When I run a debug tftp events, I get the following -
Jul 26 20:14:04.833: TFTP: Looking for CTLFile.tlv
Jul 26 20:14:04.849: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 26 20:14:04.849: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3419 for process 269
Jul 26 20:14:04.937: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 26 20:14:05.001: TFTP: Looking for CUPC/AppDialRules.xml
Jul 26 20:14:05.037: TFTP: Looking for CUPC/DirLookupDialRules.xml
not sure if it helps but
debug voice register events
Jul 26 20:15:07.840: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:07.840: auth absent
Jul 26 20:15:07.840: VOICE_REG_POOL: key(154714E70481E4BF) added to nonce table
Jul 26 20:15:12.136: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:12.136: auth present
Jul 26 20:15:16.556: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:16.556: auth present
Jul 26 20:15:17.388: EVENT: 1 node in nonce tree obsolete
Jul 26 20:15:17.388: VOICE_REG_POOL: deleted key(C4E2344F0481CC53) from nonce table
Jul 26 20:15:18.004: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:18.004: auth present
Jul 26 20:15:47.389: EVENT: 1 node in nonce tree obsolete
Jul 26 20:15:47.389: VOICE_REG_POOL: deleted key(5DFE01DE0481DC49) from nonce table
------------------------ here are the configs on my UC520
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register dn  1
number 217
name Test Iphone
no-reg
label 217
voice register global
mode cme
source-address 10.1.1.1 port 5060    <====== this originally had my vlan 1 IP address.  I changed this to vlan 100 IP address
max-dn 224
max-pool 56
load 7971 term71.default
authenticate register
authenticate realm domain.com
hold-alert
voicemail 400
tftp-path flash:
create profile sync 0467524178137408
voice register pool  1
registration-timer max 720 min 660
id mac 8C58.7764.xxxx
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username 217 password 217
codec g711ulaw
Can someone shed some light on my issue?   thanks!
21 Replies 21
johschaf
Level 4
Level 4
Hello jyoopro4ia,
Are you using 217 for the username and password? What type of iPhone are you using, and what version of iOS(Apple's not Cisco's)?
-john
john,
yes 217 is username & password.  I'm using Iphone 4 and using iOS 5.1.1
Hello jyoorpro4ia,
Did you follow this configuration guide? https://supportforums.cisco.com/docs/DOC-24508
-john
John,
Yes I did.  I see that Jabber also requires a license to be purchased.  Will not having the license cause the "invalid credentials" error?  What is the product SKU for the license?
Thank you.
Hello jyoopro4ia,
Jabber doesn't require a license(other than a normal user license). If you are trying to connect over a VPN, then that requires an ASA with a AnyConnect VPN license. You said that you are trying to register your iPhone locally, correct?
Have you tried just deleting and recreating the phone? Can you post a full debug of the TFTP events while the phone is trying to register?
-john
correct.  Locally, not over VPN.  I'll post up the debugs shortly.
John,
Should the above IP address be voice vlan IP of phone system or data vlan IP?  just wanted to confirm it should be voice vlan IP.
I am getting this debug info (show debug tftp events)
Jul 31 19:35:02.375: TFTP: Looking for CTLFile.tlv
Jul 31 19:35:02.403: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 19:35:02.603: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 19:35:02.627: TFTP: Looking for CUPC/DirLookupDialRules.xml
and getting Unable to verify account information on the Jabber client.
Hello jyoopro4ia,
The voice register global source-address is correct, it is the UC's IP on the voice vlan.
As for the debugs:
I wouldn't worry about the CTLFile or CUPC files, those show up in my TFTP debug but they are not on the flash. However, SEP8C5877646102.cnf.xml does matter. Does the TFTP events show that file being opened?
Also, can you post the following:
voice register DN
voice register pool
-john
John,
Those 4 lines are the only things I see during debug of tftp events.  Nothing more.  I don't see that file being opened at all.
Please see my original post for the voice register global, register dn and register pool.
Hello jyoopro4ia,
Hhhhmmm, under telephony-service what is the location of the CNF files? System or flash? If flash, do you see the cnf.xml file in the flash? If not, do a "no create cnf"  and then a "create cnf" and check again.
-john
Hello jyoopro4ia,
Also, under the voice register global configuration, can you remove the following: "authenticate realm domain.com"
-john
John,
It looks like I'm getting further... I checked telephony services and I did not see the following lines in the config -
(the system dates back when UC520 was first released)
cnf-file location: flash:
I added the above line.
Also, I removed "authenticate realm domain.com" from voice register global as well.  I recreated cnf and voice register profile.  When I tried initially to register Jabber, the debugs looked good and showed the phone registered, however it was not able to create a dial-peer due to memory issues (my other discussion that you were assisting me with - https://supportforums.cisco.com/message/3693878#3693878).  Too bad I didn't get to copy this debug output.
Register attempts after the first one looks only like this -
Jul 31 20:29:32.967: TFTP: Looking for CTLFile.tlv
Jul 31 20:29:32.995: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 20:29:32.995: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3416 for process 269
Jul 31 20:29:33.059: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 31 20:29:33.119: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 20:29:33.151: TFTP: Looking for CUPC/DirLookupDialRules.xml
Although I am still unsuccessful in getting Iphone Jabber registered, I feel like I'm a step closer to resolution.
Hello jyoopro4ia,
Did the jabber phone register at one point? You said: "When I tried initially to register Jabber, the debugs looked good and showed the phone registered"
Are you still getting the invalid credentials error? If so, can you create a username/password with at least 6 digits, since that is what worked for me in the lab.
-john
yes it looked like it was trying to register on my first attempt after making the config changes but I cannot replicate it anymore.  I changed the username & pw to 6 chars (123456 / 123456) and am still getting invalid credentials error.
here is the debug output
Jul 31 21:00:22.154: TFTP: Looking for CTLFile.tlv
Jul 31 21:00:22.182: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 21:00:22.182: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3425 for process 269
Jul 31 21:00:22.250: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 31 21:00:22.310: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 21:00:22.350: TFTP: Looking for CUPC/DirLookupDialRules.xml
