UC520 BRI doesn't answer
ardenta
Outbound calls from our UC520 work fine via a single BRI interface.  However when I make incoming calls I get number unobtainable.  I have logged a fault with BT and they say the line is fine.  I have a single BRI interface in the ALL_BRI trunk group.
I have tried to configure a direct dial on the DID number to  call the auto attendant or a hunt group.  Neither works.
Does anyone have any tips on where to look next?
7 Replies 7
Saurabh Verma
Level 4
Level 4
I would look at the isdn debug output to see what's being passed by BT as the DNIS. We will need to make sure that we map the correct DNIS to AA/Opertor, etc.
Can you capture the ISDN debugs and also post your current config?
Saurabh
Which ISDN debugging will show what I need:
ar_ucs_sibc_01#debug isdn ?
  all       ISDN debug messages
  api       ISDN Application Program Interface(s)
  cc        ISDN Call Control
  error     ISDN error messages
  events    ISDN events
  mgmnt     ISDN management
  q921      ISDN Q921 frames
  q931      ISDN Q931 packets
  standard  Standard ISDN debugging messages
  tgrm      ISDN TGRM events
ar_ucs_sibc_01#
I have attached the config file.
debug ISDN q931 should show you what you need.
Here is the output I get when I try to dial the number:
ISDN BR0/3/0 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band info
        Called Party Number i = 0x81, '782628'
                Plan:ISDN, Type:Unknown
ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
ISDN BR0/3/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x8081 - Unallocated/unassigned number
ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
BT is presenting 6 digits, as it should.  The problem is you are expecting all digits (including STD).  So you need to change the following
1.  Dial Peer 3010 nees to have:
incoming called-number 01932782628
changed to:
incoming called-number 782628
2.  Change your translaion rule:
voice translation-rule 8
rule 1 /01932782628/ /501/
to
rule 1 /782628/ /501/
That should work
Yes, that worked!  Many thanks for your help.
Want to clarify that all the troubleshooting and configuration for this setup could have been done through CCA :)
Did you use CCA to make the config changes?
-Saurabh
