05-10-2009 06:30 PM - edited 03-21-2019 01:05 AM
Hi there I recently installed a UC520 in my office for testing and I have a problem that when calling from outside (My mobile for example) the phone shows (From Unknown number) message I checked an article talking about the same problem but it did not work for me, so I'm wondering if there is any caller-Id option need to be modified.
My UC520 is intalled in KSA with STC service provider and the caller-ID service is working (tested by a normal phone) and here is the configuration that I have for the voice-port:
voice-port 0/1/1
cptone SA
connection plar opx 202
description Configured by CCA 4FXO-0/1/1-Custom
caller-id enable
can you help me with that ?
Solved! Go to Solution.
05-10-2009 06:36 PM
Hi there,
We have seen in the past that some providers in Saudi Arabia don't use Bellcore standard for CLID (which is what "cptone SA" invokes). Go ahead and use another profile, "cptone BR" for Brazil and don't forget to do a "shut", "no shut" of the voice port.
Let us know how that works.
Marcos
05-10-2009 06:36 PM
Hi there,
Marcos
05-10-2009 07:21 PM
Thank you for you response and your time:
I tried what you said but it did not work out I tested that with almost all the profiles and I even tested it after removing this command but I still cannot get the CLID on the phone screen.
any suggestions ?
05-10-2009 07:35 PM
Try cptone BR again and add this command
caller-id alerting ring 1
Don't forget to bounce the port. If that doesn't wok, we'll take a look at some debugs.
Marcos
05-10-2009 08:22 PM
Hi ,
It did not work for the command caller-id alerting ring 1 but I tested it with the commant caller-id alerting dsp-pre-allocate and it worked, of course as you said the command cptone BR is used, so now the configuration of the voice-port 0/1/1 is:
voice-port 0/1/1
trunk-group ALL_FXO
cptone BR
05-10-2009 08:24 PM
Good to hear.
Thanks a lot,
Marcos
08-03-2009 09:25 AM
Dear Friend
I have flow your config its work good to see incomming caller number, but i am facing sum problem can you reviez your config?
1. if sum calling from out site on internal no answer its keep ring unless sum one left handset and close it but PSTN line is free dooring this ringing
2. if sum one dialing hunt group number for internal calls are droping when we select CP Tone BR
can do this excersize on your system if can i will appreciate to you
Taher
08-03-2009 04:41 PM
Hi Taher,
I apologize, but I am not exactly sure of what you are asking here or asking me to do. Can you describe your problem a little more?
Marcos
08-03-2009 10:17 PM
Hi Taher,
for me also your problem is not clear, you are talking about totaly different things. please explain your problem more.
08-04-2009 12:45 PM
First of all I like to say thanks to guyes
As Mr Hanichaban mentioned its working in KSA, I have followed the config, my voice gateway is Cisco 2811, & I am using CUCM 7
Voice-port 0/0/0
cptone BR
Connection plar opx 861
Description Auto Attendant
Caller-id alerting ring 1
Caller-id alerting dsp-pre-allocate
Caller-id enable
its work but I have sum issues see bellow
i have auto attendant menu [861]
1 for sale, [hunt group in these 4 members]
2 support,
3 dial by ext
1. If incoming caller dialing [1] sales it’s reaching to hunt group which is one of them Ext 300 its ring with caller id, once we answer call will be dropping
2. if incoming caller dialing [1] sales its reaching to hunt group which is one of them Ext 300 its ring with caller id, if no answer call will be keep ringing even 1 hr never drop, but out site caller PSTN line are free
I think will be easy to understand this if you are feeling difficult to understand so please drop me your number I will call back to where ever you are
Taher
08-04-2009 07:16 PM
Taher,
I am sorry to inform you that we do not support ISR (1800/2800/3800) questions on this forums. Please try Netpro as an option:
http://forum.cisco.com/eforum/servlet/NetProf
Marcos
