Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1600
Ruslan_Tugushev
Beginner
UC520 CUE AA problem.
Hello!
Tried to google this problem, but not yet figured out.
I've got UC520 (cue 3.2; 15.0(1)XA2; CME 8.0) with standart 8 user licence. It was previously configured(not by me, however
everything is working fine), now company needs auto-attendant functionalty.
I've configured aa using GUI in CUE, then I created dial-peer pointing on Integrated-Service-Engine. And now when I try to dial aa pilot number using internal IP phone I get busy tone and "unknown number".
CUE configuration:
I created script with mostly default params using gui.
Then created aa, and attached previously created script to it, after that I just typed in pilot number 5000.
My conf:
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
dial-peer voice 2222 voip
destination-pattern 5000
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
Thanks in advance.
Ruslan.
6 REPLIES 6
David Trad
Rising star
Hi Ruslan,
Just to confirm with you, your dial-peer 2222 is that you VM pilot number or your AA pilot number?
When you created the AA in CCA this should have also configured the CME side unless CCA could not work with the configuration.
Please show me your VM dial-peer and also the AA dial-peer please
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
dial-peer 2222 - is dial peer for AA.
AA's pilot number - 5000
Voice Mail Phone Number*: 778
dial-peer for VM:
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 778
redirect ip2ip
b2bua
codec g711ulaw
no vad
dial-peer for AA was in previous post, but anyways:)
codec g711ulaw
Can you please post your CUE running configuration, in a TXT file format as an attachment please?
Just remove any sensitive stuff
Cheers,
David.
Here it is.
Nothing sensitive I guess.
Well, I've got some ideas. Can it be because of several aa's are configured? may be some license issue? I tried "sh license status application" in cue cli, no such command. Or is there ccn trigger limit?
When I dial voice-mail pilot number I have the same problem.
I'm new to voice.))
Hi Ruslan,
I believe you may have a licensing issue
If I am not mistaken you might be going over what the CUE can support, please contact SBSC support to have your setup checked, you may need to look at your strategy surrounding the way your using the system and check if there is a more eficient way of doing things.
Cheers,
David.
For a fresh start, can you upgrade to software pack 8.2 ?
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=UC500
Then if still trouble, there is a number of diagnostic steps that can be taken.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
