UC520 - CUE CF Card Replacement how to ?
tuandatnv
I have UC520 since 2007 and few days ago the CUE was broken down, I found out that CUE CF Card 1G was failed to work
I bought a new CF card 4G to replace it, format it as FAT16, and tried to transfer CUE file to this CF Card using CCA and then TFTP, but it was unsuccessful.
While looking at the error messages from old and new card, I found out the file system of CUE CF Card were unable to mount, and the format the CUE want to use was reiserfs (the one Linux file system), and looking at the old card (1G) error message, I found there were 02 partitions (hda1, hda2)
Did any one have problem with CUE CF Card broken, please advise how to partition and format CUE CF Card to upload CUE data
I urgently looking forward for help
Tom
Bellow are some log messages
1. When loading old broken CUE 1G CF Card
Cisco BootMon Version: 1.0.2
(Feb 27 2007 - 10:38:53) MPC83XX
Bootmon starts
Bootmon: cold reset.
System now booting.
Bootmon: reading primary bootloader image
Bootmon: calling bootloader
Cisco ServiceEngine Bootloader Version: 1.0.3
(Jul  6 2007 - 10:15:37) MPC83XX
Resetting devices ....Done.
mac address for internal ethernet 00:1b:8f:ac:15:fe
Please enter '***' to change boot configuration:
ServicesEngine Bootloader Version : 1.0.3
kern_sz: 1128866
bl_boot_cf_cmd root=/dev/hda1 install_root=ide ro plat=freddo
## Booting image at 04000000 ...
   Image Name:   Linux-2.6.22-cisco-freddo
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    1128802 Bytes =  1.1 MB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Linux version 2.6.22.10-vs2.2.0.5-cisco-freddo (drodrig@fndn-bld-system1) (gcc version 4.2.2) #1 Wed Jun 9 18:44:37 PDT 2010
Zone PFN ranges:
  DMA             0 ->   131072
  Normal     131072 ->   131072
early_node_map[1] active PFN ranges
    0:        0 ->   131072
Built 1 zonelists.  Total pages: 130048
Kernel command line: root=/dev/hda1 install_root=ide ro plat=freddo
Platform: ise
IPIC (128 IRQ sources, 8 External IRQs) at fe000700
PID hash table entries: 2048 (order: 11, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 515840k available (1756k kernel code, 516k data, 92k init, 0k highmem)
in atrace_init
log_head: h: 0, t: 0, l: 0, w: 0, s: 1047488
Using existing trace log
Mount-cache hash table entries: 512
NET: Registered protocol family 16
Generic PHY: Registered new driver
SCSI subsystem initialized
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Cisco ContentEngine Flash Driver Version 0.03
ceflash: Can't register misc device <NULL>
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xe0004500 (irq = 9) is a 16550A
serial8250.0: ttyS1 at MMIO 0xe0004600 (irq = 10) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize
Gianfar MII Bus: probed
eth0: Gianfar Ethernet Controller Version 1.2, 00:1b:8f:ac:15:fe
eth0: Running with NAPI enabled
eth0: 256/256 RX/TX BD ring size
eth1: Gianfar Ethernet Controller Version 1.2, 00:1b:8f:ac:15:ff
eth1: Running with NAPI enabled
eth1: 256/256 RX/TX BD ring size
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
hda: probing with STATUS(0x50) instead of ALTSTATUS(0x0a)
hda: STI Flash 7.4.2, CFA DISK drive
ide0 at 0xe1000000-0xe1000007,0xe100280d on irq 17
hda: max request size: 128KiB
hda: 2001888 sectors (1024 MB), CHS=1986/16/63
hda: cache flushes not supported
hda: hda1 hda2
i2c /dev entries driver
NET: Registered protocol family 26
TCP cubic registered
NET: Registered protocol family 17
ReiserFS: hda1: found reiserfs format "3.6" with standard journal
ReiserFS: hda1: using ordered data mode
ReiserFS: hda1: journal params: device hda1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda1: checking transaction log (hda1)
hda: status error: status=0x51 { DriveReady SeekComplete Error }
hda: status error: error=0x05 { DriveStatusError AddrMarkNotFound }, CHS=1050/4/5, sector=1058656
ide: failed opcode was: unknown
hda: no DRQ after issuing MULTWRITE
ide0: reset: master: controlling MPU error
end_request: I/O error, dev hda, sector 1058656
Buffer I/O error on device hda1, logical block 131072
lost page write due to I/O error on hda1
end_request: I/O error, dev hda, sector 1060680
Buffer I/O error on device hda1, logical block 131325
end_request: I/O error, dev hda, sector 10208
Buffer I/O error on device hda1, logical block 16
end_request: I/O error, dev hda, sector 1064232
Buffer I/O error on device hda1, logical block 131769
ReiserFS: hda1: warning: journal-1226: REPLAY FAILURE, fsck required! buffer write failed
ReiserFS: hda1: warning: Replay Failure, unable to mount
List of all partitions:
0300    1000944 hda driver: ide-disk
  0301     995904 hda1
  0302       5008 hda2
No filesystem could mount root, tried:  reiserfs
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(3,1)
Rebooting in 180 seconds..
2. When loading CUE new 128M CF card (FAT16 Format)
hda: STI Flash 7.4.0, CFA DISK drive
hda: 250880 sectors (128 MB), CHS=980/8/32
hda: hda1
0300     125440 hda driver: ide-disk
  0301     125372 hda1
0 Replies 0
