12-08-2011 07:23 AM - edited 03-21-2019 05:03 AM
I have a customer with a UC520 that has two analog lines in. Frequently both lines are in use and they are missing calls. I suggested it might be time to add another line. They called the Telco and someone told them that they don't need another line that the CISCO will forward to voicemail. I am having trouble understanding how this can work if both the lines in are in use.
Am I missing something???
If anyone can answer this it would be greatly appreciated.
12-09-2011 08:35 AM
The Telco is incorrect. With only two FXO lines open, there is no path for the third call. For small systems of two lines, I recommend to the client to use the Telco voicemail (on the lines). Place the lines on a set (As Co Type Lines) so the client can use the button to dial the * code to access the telco voicemail system.
The Cisco voicemail system is internal voicemails only.
You will need to set the call-forward noan timeout to a duration lower than the telco. That way, the telco voicemail will engage before the UC520 does on calls that are not answered.
12-09-2011 08:42 PM
Hi There,
I think you will find that the Telco was referring to their own VM system, if they weren't then clearly they have no clue what they are talking about and need to go back and get some training.
If you are going to upgrade to more than 4X FXO lines at any stage, then I would recommend you go down the ISDN path, much more better technology which does not suffer the same issues as an Analogue service, such as line lock-ups etc..
Cheers,
David.
12-12-2011 09:28 AM
David is right about FXO's, old tech with some headaches, though it can serve as a reliable backup to your primary ISDN or SIP.
