Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1674
Beginner
UC520 Outgoing Call Digit
anyone know how I can change the digit that must be pushed to get access to an outgoing line?
thanks
Everyone's tags (4)
5 REPLIES 5
Highlighted
Hi Jesse,
If you are using CCA please go to configure->telephony->dial plan->outgoing dial plan. There you may change the prefix.
If you are using CLI you need to modify the dial-peer for outbound calls and under the outgoing voip dialppers you need to add translation rules.
HTH,
Alex
*Please rate helpful posts
Highlighted
Beginner
This is the area I felt I should change and we wanted to dial 8 for that outside line but when I changed the bolded area's destination pattern to start out with 8 there were issues and I didn't get to an outside line? could something be conflicting or did I miss something? thanks
dial-peer voice 54 pots
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 55 pots
preference 5
destination-pattern 911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 56 pots
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 57 pots
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 58 pots
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 60 pots
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 61 pots
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 62 pots
preference 5
destination-pattern 91888.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 63 pots
preference 5
destination-pattern 91877.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 64 pots
preference 5
destination-pattern 91866.......
port 0/2/0:23
forward-digits all
no sip-register
Highlighted
Hi Jesse,
Please check the rules in the OUTGOING_TRANSLATION_PROFILE how the digit manipulation is done.
HTH,
Alex
Highlighted
Beginner
voice translation-rule 1112
rule 1 /^9/ //
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
Highlighted
Beginner
I figured it out with that little push from Alexander. thanks. basically these are the areas that need to be changed. cisco is nice and modulated so one item references another. I think this situation is nested about 3 levels deep. I'll document to help others.
Change the rule to look for 8 in that first digit
rule 1 /^8/ //
Have a voice translation profile setup which references the voice rule we just made
have your dial peers change their outgoing pattern and make sure it references the translation profile above
preference 5
destination-pattern 8[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 8[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 8011T
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81800.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81888.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81877.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81866.......
port 0/2/0:23
forward-digits all
no sip-register
to change dial tone to 8 do the following
telephony-service
  secondary-dialtone 8
