ā07-23-2012 11:39 AM - edited ā03-21-2019 06:04 AM
I wanted to try out Jabber so I decided to upgrade the IOS/CME only from
uc500-advipservicesk9-mz.151-2.T4 (UC520 8.2)
to
uc500-advipservicesk9-mz.151-4.M4b (UC520 8.6)
Ever since the upgrade, I'm having the following problems -
1. MWI not working
2. Cannot add new ephones or dial-peers without rebooting the system. I'm getting this "ERROR: could not add peer" error message. When I reload the UC520, I'm able to add again. Could this be caused by some type of memory/resource leak?
Anyone else having similar issues? I'm tempted to downgrade to 151-2.T4 to see if the problem happens with that version as well.
Also, is there an updated ROM monitor file for the UC520?
My UC520 is still on
ROM: System Bootstrap, Version 12.4(11r)XW, RELEASE SOFTWARE (fc1)
Thank you
ā07-24-2012 05:34 PM
For "1.MWI not working" , have you tried refleshing Messgage Waiting Indicator setting in CUE interface ?
ā07-24-2012 08:56 PM
Hello jyoopro4ia,
A few things to check here:
1. First find what your MWI on and off DNs are.
2. Then do a show voice port summary and see if the MWI ephone dns are idle or in use.
3. If the dns are idle, do a csim start A800... where ... is the extension. This should turn on MWI on the phone
4. If the MWI dns are idle and you can force the MWI on/off, check if you have this in the configuration:
voice service voip
sip
bind control source-interface Vlan100
bind media source-interface Vlan100
If so, remove those bind statements.
4b. If the MWI dns are in use, kill the call to the dns, delete the dns, and recreate them.
5. Test the dns again using the csim start A800...
6. If that still fails we need to configure the UC to use unsolicted MWI notification
In CME:
sip-ua
mwi-server ipv4:10.1.10.1 expires 3600 port 5060 transport udp unsolicited
In CUE:
ccn subsystem sip
mwi sip unsolicited
end
mwi refresh all
As far as the dial peer issue you can check the memory and processor using these commands:
show memory debug leak
show processes cpu history
Do you get a crash log or error code from the UC after the dial peers are added and the UC reloads?
-john
ā07-25-2012 11:18 AM
I have been fighting this MWI issue as well for a week, your post just sorted me out in about 5 minutes!
Items 1-4 worked like a charm, as soon as I removed those binds and refreshed things and poof, lights all over the place.
Thanks.
That should have been a 5 star rating, anyway I can change that?
ā07-25-2012 11:28 AM
John,
I'm looking fwd to trying to this when I return to office. From Brian's comments, it looks promising!
i'll let you know about #2 as well.
ā07-25-2012 01:23 PM
Looks like removing those binds fixed the issues. Thanks John.
Time to look at the dial peer issue......
ā07-25-2012 01:35 PM
John,
Without reloading, I cannot add dial peers (or ephone-dns). Only immediately after a reload, I am able to do so. It looks like reloading clears up resources to allow me to add.
As I just mentioned, I am not able to add ephone-dn's as well. I get the same error message.
I ran both show commands you recommended and I don't see anything too crazy... Any other thoughts?
ā07-25-2012 01:38 PM
Hello jyoopro4ia,
Under telephony-service you should see the max ephones and ephone-dns listed. Can you verify that the additional ephones and ephone-dns are not exceeding the limit?
-john
ā07-25-2012 01:46 PM
correct. I can verify that.
I am not going over the limit listed under telephony-service.
ā07-26-2012 10:47 AM
John,
The two lines you had me remove -
voice service voip
sip
I read that when using Cisco Jabber above two lines are required. Can you confirm that?
ā07-26-2012 12:09 PM
Hello jyoopro4ia,
Not that I'm aware of. Can you provide me the documentation where you saw that?
Here is the guide for Jabber on UC500: https://supportforums.cisco.com/docs/DOC-24508
If you have issues with Jabber after removing those bind statements, you can use the unsolicitied MWI notification method.
-john
ā07-25-2012 01:56 PM
Seems to me you're running in a know issue of memory leak, that cisco has never really dealt with. See
https://supportforums.cisco.com/message/1121799
and more cases too.
Personally, I would try cleaning and reducing configuration via CLI
