Just curious, if I use SIP Trunks and want to use the auto QoS features, do I basically just first set under the SIP Trunk the number of max concurrent calls, so say 8 for example, and then under Traffic Shaping limit it to say 20% of my upload which is 5Mbps which would reserve 1Mbps for voice at all times? Just wondering if there's anything else in CCA I need to do to make sure SIP always has priority over data or if that's basically it? No issues as of yet just want to be sure it's done right.
