09-01-2010 07:39 AM - edited 03-21-2019 02:57 AM
Dears,
Please advice what is the correct process to shut down the UC520.
Thanks & Regrds,
Mohammed
09-01-2010 07:50 AM
here is what I do...
Save the running configuration using CCA or CLI 'write memory' so the running config gets written to the startup-config used next time its plugged in.
Unplug the LAN ports and expansion port cables to make sure there is nothing reading or writing to Flash memory.
Unplug it.
09-01-2010 08:00 AM
Thank you Steven,
Sorry if the question is not clear, I mean how to correctly shutdown the UC520 to prevent CUE damage.
Thanks in advance.
Mohammed
09-01-2010 08:02 AM
Removing the power is the shutdown. There are no spinning disks.
09-01-2010 08:38 AM
OK, thank you Steven for your fast respone.
And It's clear now.
Best Regards.
Mohammed
09-02-2010 07:30 AM
I would shut the CUE module down before pulling the plug. You don't want to pull the plug on a *nix environment, regardless of if there
is a spinning disk or not. CUE could be writing to the database at the time you pull the plug, and you may corrupt something there.
!Saves config
CME# se i0/0 sess
CUE# wr
Ctrl + Shift + 6 then hit 'x' to drop back to the router prompt after this.
CME# se i0/0 shutdown
(Hit Enter twice if you want to watch the module's shutdown messages.)
