Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
1065
Beginner
UC520 version 8.6.2 Voicemail will not work
We have a UC520 that we erased and reinstalled 8.6.2. After installing and configuring - via CCA Wizard - voicemail does not work. If you call the voicemail extension it just has dead air. If you call an extension and the user for the extension is busy, no answer or selects DND you get dead air. Rebooted system, reinserted compact flash. Configured as a PBX and did it again and configured as a Key System with same issues. Any suggestions?
Everyone's tags (4)
10 REPLIES 10
Enthusiast
What happens when you check the CUE status? Can you ping CUE at 10.1.10.1?
-john
Beginner
According to the CCA voicemail diags, it responds voicmail is opperational. No I cannot ping 10.1.10.1. I can connect to 10.1.1.1, 10.1.1.1/ccme, 10.1.10.2. Yet cannot connect to 10.1.10.1.
Thanks appreciate the assistance.
Enthusiast
Ok, you need to add a route either on your PC or your default gateway to the CUE network. If you are unable to communicate with CUE and are using CCA, it is possible the necessary configurations are not present in CUE, since your PC is unable to communicate with CUE. Once you can access CUE web interface, check the call-in numbers configuration.
-john
Beginner
The following is the route listed in running config via CLI
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
Enthusiast
But is the UC your default gateway?
-john
Beginner
Yes, it is my default gateway. We configured via cca wizard. Pretty much answered questions. Used almost all defaults, except wan address of course.
Enthusiast
Can you post the configs for the following:
Service-module Integrated-Service-Engine 0/0
Loopback0
Can you session into the CUE in CLI and tell me what you get?
Service-module Integrated-Service-Engine 0/0 session clear
Enter you login credentials
Hit enter again
-john
Beginner
Used your 2nd command service-...session. I was able to enter into se-10-1-10-1#. Didn't use the ... clear command. Did you want us to run that command?
I also attempted to upgrade/reinstall the voicmail package only via CCA Maintenance, restart/reset. Once it got to backup said it could not go forward because cue could not communicate to pc.
Beginner
Correction on my last post. I attempted to upgrade via CCA Maintenance button but via the upgrade then uc500 folder under the Maintenance button.
Also here is what our loopback looked like.
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
Enthusiast
Ok, it sounds like you can get command line access to CUE, but something is preventing you from connecting to CUE by IP.
and
show ip route
-john
