2342
Highlighted
Beginner
UC520 with 9971 Integration
I recently updated the OS on my UC520 the newly released version and tried my hands on a 9971.  I was able to add a regular like to the phone to test calls.   I am using the latest CCA to program the system.   I don't see any options on CCA to add PARK extensions or take advantage of all the line buttons.   Does anyone else have this issue?  Any work around to it?
9 REPLIES 9
Highlighted
Beginner
i will let you know when my 9971 turns up in the next few days
UC540 system with 8.6 Software Pack
UC540 system with 8.6.2 Software Pack
Highlighted
Enthusiast
Sunil,
So far I have only seen the ability to add this via CLI. I am working on this configuration and I will post when I get it tested. I had this working on a CME Router now I just need to port it to the UC.
Stay Tuned.
Highlighted
In the latest CCA version 3.2(1), Call park feature is not supported for SIP phones (8961,9951,9971 and IPhone mobile client). To enable this feature for SIP Phones, we need to configure manually .
Call park system application configuration has to be pushed globally under telephony-service.
Please follow the below steps ,
Router(config)# telephony-service
Router(config-telephony)# call-park system application
Router(config-telephony)# exit
Saravanan.
Highlighted
I know this is an older post, but this solved my "no call park" issue with the 9971 on a uc560.
Now if I can just get the rest of it to work.
Highlighted
Hi, I know this is old too, but how did you go with getting the 9971 'more' integrated into a UC540 system?
Highlighted
We never did, we ended up returning the 9971 as most of the features are/were not supported on the UC series.  We purchased it for the receptionist, but you could use any of the addon modules for the 9971 on the UC560.
We ended up taking a large hit on the "restocking fee" on the 9971 and 2 addon modules.
Highlighted
thankyou! this helped me too! :)
Highlighted
Beginner
Has anyone successfully integrated the 9971 with uc520? Does everything work?
Highlighted
I have some working fine, there are limitations like no pickup as some of the buttons aren't there. There is a document I saw somewhere that says what doesn't work.
Video works between them as we'll.
Bob James
