Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
702
Highlighted
Beginner
UC520W Restore Issues
I just purchased a used UC520W for home office. I reset to factory defaults by copying the factory config (UC520W-16U-4FXO-K9-factory.cfg) to the startup.
I plug a PC into 0/1/0 (1st of the 8 POE Ports), and the machine is not reciving a IP from DHCP. I tried to set a static IP, etc however no matter what I do I cannot connect to the UC520 from CCA.
This UC520 will be used only for Call Manager. Wish to just plug into network along with the phones. Routing & switching is done with other cisco gear. Also, I wish to use the WLAN in the UC520 for a single ssid for my 7925's to connect to.
Phones & PC's are all on one VLAN now.
Any help would be appeticated.
Thank You!
12 REPLIES 12
Highlighted
Hall of Fame Master
Wrong forum, post in "small business voice - UC500". You can move your post using the actions panel on the right.
Highlighted
Beginner
Hi bndbrennan,
Can you get the following outputs:
show run interface fa 0/1/0
show run | se dhcp
You need to ensure that the interface you are plugged into is configured as untagged in your data vlan.  Also, you need to ensure you have DHCP configured correctly for that VLAN.
Let me know,
-Trent Good
-Trent Good ** Please rate useful posts! **
Highlighted
Beginner
Hi Trent,
Thank You. Below is the "show run interface fa 0/1/0" and the "show run" as "show run | see dhcp" did not return anything.
Router>en
Router#show run interface fa 0/1/0
Building configuration...
Current configuration : 35 bytes
interface FastEthernet0/1/0
end
Router#
Router#show run
Current configuration : 1636 bytes
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid UC520W-16U-4FXO-K9 sn FHK114312W2
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login
transport input all
end
Highlighted
Beginner
Re: UC520W Restore Issues
Hi bndbrennan,
You don't have any IP address information on the device.  Also, this doesn't look like the factory default config.  It looks like the result of a write erase.
You may trying to set the config register to 0x2102 as it looks like it is booting to the initial config:
conf t
config-register 0x2102
Typically on a UC640/560 the factory default file is about 23kb,
yours is about 1.6kb.  Not sure if there is a difference between
the 520 factory default and 540/560 factory default though.
Otherwise to get access via CCA try the following:
conf t
int vlan 1
ip address 192.168.10.1 255.255.255.0
no shut
exit
ip dhcp pool data
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
You may double check your factory default file as there are some voice specific information that is included in it which your configuration doesn't appear to have.
-Trent Good
Highlighted
Beginner
I ran those commands, and also set an ip address for the Integated-Service-Engine0/0
PC gets address from DHCP when plugged into POE switch port 1. Address is 192.168.10.2
I open CCA, I try to add 192.168.10.1 or 192.168.9.1 (Integated-Service-Engine0/0).
I am prompted with a login window stating ...realm "level_15_access" on "ipaddress"'
Is this what I want to happen? What would the default login be? Do I connect to the Integated-Service-Engine0/0 or the 192.168.10.1 address?
Highlighted
Beginner
Hi bndbrennan,
Try the following:
username cisco privilege 15 secret 4  tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
-Trent Good
Highlighted
Beginner
Thank You.
I was able to get access to the UC520 via CCA via the 192.168.10.1 address. However, when loading any of the telephony items, it says "loading voice related data"..The progress bar fills up and it keeps going, right now this one has been up for 54 mins.
Highlighted
Enthusiast
Based upon the previous configuration you posted, it doesn't appear that the factory default was completed, as there a lots of default configurations missing.
How did you restore the factory configuration?
-john
Highlighted
Beginner
Trent- Thank you very much for your help!
Hi John,
I copied the file (UC520W-16U-4FXO-K9-factory.cfg) that was in flash, to startup...
Highlighted
Enthusiast
Im wondering if that file has the actually factory config. You might want to download Software Pack 8.6.2 and grab the latest factory config file from there.
You can check the factory config file in CLI by doing the following:
more flash:/UC520W-16U-4FXO-K9-factory.cfg
The factory config files should have a default cisco admin user, 192.168.10.1 programmed on vlan1, the voicemail module Integrated-Service-Engine0/0 IP configuration, etc. That information doesn't appear present in your factory config file.
-john
Highlighted
Beginner
Thank You. I have downloaded the pack, and go to install/upgrade before doing a restore in CCA, and the wizard hangs up at the "Ping Test from CUE to CCA". Im going to reboot everything and give it another try now.
Highlighted
Enthusiast
According to the config above, the voicemail system, CUE, can't communicate with your PC. This is because the voicemail system, doesn't actually have an IP address in your configuration.
From command line, you need to copy the factory config file into flash, save that config to the startup config, reload the UC, and then do the upgrade in CCA. After that point, you can do a restore or start the initial config.
-john
