06-06-2011 08:20 AM - edited 03-21-2019 04:11 AM
Dear All,
I have the following configuration, concerning Auto Attendand, running on UC540:
dial-peer voice 502 voip
description $AUTO ATTENDAND$
destination-pattern 298
b2bua
session protocol sipv2
session target ipv4:10.3.3.162
voice-class sip outbound-proxy ipv4:10.3.3.162
dtmf-relay sip-notify
codec g711ulaw
no vad
Unity Express:
ccn trigger sip phonenumber 298
application "autoattendant"
enabled
maxsessions 6
end trigger
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 6
script "aa.aef"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "allowExternalTransfers" "false"
parameter "MaxRetry" "3"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "businessSchedule" "systemschedule"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "206"
end application
When I call 298 from internal number, I hear the prompt, select 0 or 1 and everything is OK. When i try from outside (mobile) number I hear the prompt, select 0 or 1 (dtmf work) and I don't here anythin after that. I receive this error in the debug message:
002069: Jun 6 18:17:40 EEST: //1487/F1D1F58B8684/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
I said that the dtmf works, because if i press "1" I hear the prompt enter the phone number you trying to reach.
Any tips?
Solved! Go to Solution.
06-06-2011 08:48 AM
Hello Velin,
Your AA dial-peer appears to have the correct configuration even though changing the cue ip address isn't recommended. What kind of incoming trunk are you using, Sip, PRI, FXO? It would be helpful to take a look at your incoming dial-peer configuration. With some sip providers, the issue may be on their end.
Marvin
06-06-2011 08:48 AM
Hello Velin,
Marvin
06-06-2011 08:56 AM
I use SIP Trunk with the local provider. Here you are the incoming dial-peer config:
dial-peer voice 101 voip
description $SIP TRUNK FIXED INCOMING$
translation-profile incoming BTC-INCOMING
session transport udp
incoming called-number 290230T
dtmf-relay rtp-nte cisco-rtp
codec g711ulaw
I installed seveal UCs for customer of ours and I don't have the problem witch i noticed here. As I sait it seems that the dtmf working properly.
06-06-2011 09:03 AM
Fixed...
I missed some config on the voice service voip.
06-06-2011 09:15 AM
Hi, I would recommend dropping the Cisco proprietary cisco-rtp and just use the RFC 2833 standard - dtmf-relay rtp-nte for your inband signaling. You could also check with the SP and verify that the proxy server you're connecting to also supports 2833.
-Marvin
06-06-2011 09:28 AM
Was it the following,
alllow-connections h323 to h323
allow-connections sip to sip
allow-connections sip to h323
allow-connections h323 to sip
Glad to see you were able to get it going. I didn't want to recommend this without first knowing what incoming trunk type you're using.
