Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
596
Beginner
UC540 Analogue Trunk Caller Display
I have a UC540 with 2 x Analogue trunks, caller display is enabled on the trunks and caller id is displayed on the outgoing callers although all inbound calls are displaying as Anonymous.
Is there anything system related tht could affect this?
Everyone's tags (5)
2 REPLIES 2
Hall of Fame Master
Re: UC540 Analogue Trunk Caller Display
Check first that caller-id works using a regular phone.
If it does, different settings maybe needed under voice-port.
Hi Mike,
I had a similar proper during an install a week ago. I had to add "ring number 3" to the voice-ports (FXOs), so basically the UC lets it ring 3 times before the call is picked up - otherwise it was just failing to see the caller-id. Give it a go!
