UC540 and ESW520
johnroche_2
I have a UC540 and an ESW520-24P connected with a smart port.
When on the LAN or WiFi I can manage both the UC and the ESW.
From VPN however I can only manage the UC. I cant ping or browse the ESW.
The ESW is 192.168.10.2 and the UC is 192.168.10.1, i.e the UC and the ESW are on the same subnet.
Is there any known issues managing an ESW via VPN?
John
Brandon Buffin
Check the default gateway on the ESW.
Hope this helps.
Brandon
The gateway is correct the ESW.
What the default gateway address on the PC?
Can you get the "ipconfig /all" from your PC and also the "show ip int brief" output from the UC500 and attach your current 'show run' output?
Anthony
