Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
805
UC540 compatibility with VWIC3 card?
Hello all,
We have a customer using a UC540W-BRI-K9. They will move their office and upgrade their current 2xBRI lines to 1xE1 in order to have 30 channels.
as you may all know, the VWIC2-1MFT-T1/E1= is now EoL/EoS. Will the new model VWIC3-1MFT-T1/E1= be fully supported and compatible with our
UC540W-BRI-K9? It is running
Software version is a bit old though...
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 12-Jul-11 22:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
KFL-UC-01 uptime is 26 weeks, 4 days, 14 hours, 11 minutes
System restarted at 22:33:37 CET Thu Jul 12 2012
System image file is "flash:uc500-advipservicesk9-mz.151-2.T4"
Thanks for your advice.
Everyone's tags (6)
1 ACCEPTED SOLUTION
Participant
Hi Hiromichi,
As per UC540 platform reference guide, VWIC3-1MFT-T1/E1is not supported.
VWIC2-1MFT-T1/E1 is the only supported card.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-express/C78-557768-00_540_platform_reference_guide_DS_v2a.html
Kindly Rate the post accordinly.
Kevin
2 REPLIES 2
Participant
Hi Hiromichi,
Kevin
Highlighted
Thanks Kevin for your prompt answer. Then we will definitely need to go for the VWIC2.
Kind regards
