Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
637
Highlighted
Beginner
uc540 - connecting remote phone over vpn tunnel how ?
ok i got a uc540
data vlan : 192.168.4.0 /24
voice vlan : 10.1.1.0 /24
so my phone gets ip in 10.1.1.0 network and my PC get ip in 192.168.4.0 network
192.168.4.0 network is connected over vpn tunnel to network 192.168.0.0
i got a spa504g in 192.168.0.0 network, phone's ip is 192.168.0.181.
I want to connect the phone to my uc540. How can i do it ??
Also, is there a way to remove voice vlan so that the phone and pc would be in same network (192.168.4.0) and it would be a lot easier to connect phone over vpn tunnel!
I think the problem is that my phone at 192.168.0.191 can't reach tftp server which is at 10.1.1.1
So if i could delete the voice vlan, my tftp server would be 192.168.4.1 and my phone could get the conf from the uc540.
1 REPLY 1
Highlighted
Hi Tommy,
You should be able to reach 192.168.4.0, 10.1.1.0 and 10.1.10.0 if possible from 192.168.0.0 network.  This can be arranged with the access lists on your vlan and/or wan interface on the UC540 and the other side of the VPN. If this is the only phone on the other network try adding the TFTP server manually to the phone also otherwise you can add option 150 to the DHCP server.
HTH,
Alex
