UC540 Dial-plan not working
mohdibrahim01
Hi All,
i have UC540 installed with 2 FXO cards connected to them 8 Analog lines the end user requirement to block outgoing calls form all phones except operator phone i apply the call permission for all phone as internal but they still can dial out .i have two rules one for local calls and one for international calls.
how can i block the out going calls for all phones expect operator.
thanks
Moe
note :config file attached
6 Replies 6
johschaf
Level 4
Level 4
Hello Moe,
Reviewing your configuration, it looks like the corlist is configured correctly. Generally speaking, for cor to work you need:
1. Cor custom list
2. Actual list of cors to apply to the dial peers
3. The cor's linked to a dial peer
4. The cor's linked to the ephone-dn
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name internal_second_line
name local_second_line
name local-plus_second_line
name international_second_line
name national_second_line
name national-plus_second_line
name emergency_second_line
name toll-free_second_line
name international_second_line_FAC
dial-peer cor list user-internal
member internal
member emergency
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-7-digit*7-Digit Local**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
ephone-dn  281  dual-line
number 206 no-reg primary
label ******
description ******
name************
call-forward busy 399
call-forward noan 399 timeout 20
corlist incoming user-internal
translation-profile incoming CallBlocking
Cor configuration guide: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Are you using CCA or CLI to configure this UC? What version of IOS is on the UC? If you are using CCA, what version?
-john
Hi John,
UC540 configured by CCA ver. 3.0 and the its running IOS 12.4 CME 8.
Moe
Hello Moe,
It is highly recommended that you update to the current verison of the Software pack - 8.6 and CCA 3.2.1. You will get additional 8 free licenses also when you update to SWP after 8.2.
Best regards,
Alex
Hi Alexander,
Is there any bug in the IOS that im using right now and how critical is it regard the licenses  i already have enough installed .
but the issue why the dial plan not apply after i configured it and save it ?
Moe
Hello Moe,
That is the original version of IOS for the UC. That version of IOS is meant to be used with CCA version 2.1 which is no longer available.
UC500 Software Packs:https://supportforums.cisco.com/docs/DOC-9827
Please upgrade the IOS to 15.1(2)T4(Software Pack 8.2) or 15.1(4)M4b(Software Pack 8.6) and then retest the COR functionality.
-john
Hi All,
i upgrade the UC500 and reconfigure it from scratch now its working fine .
Moe
