I need some help with dial plans. We need a 10 digit dial plan as all local call must have the area code. The default that came with the US540 is North American 7 digit dial plan.
In CCA you can change the default outgoing dial plan to be North American 10 digit. You can locate that setting under Configure -> Dial Plan -> Outgoing.
Hope this helps.
-john
