10-28-2012 07:47 AM - edited 03-21-2019 06:30 AM
Hi I have a probem to configure my UC 540 in order to provide WLAN-Clients and Clients in the data VLAN access to the internet
Here my Problem:
As a result I can only use dynamic IP address with NAT enabled (Configure/Security/NAT)
For all other settings, the clients are not able to access the internet, since no DNS is set in the DHCP.
I have the newest version 8.6 and use the actual CCA 3.2(1)
Any suggestions how I can use static IP and no NAT instead of DHCP and NAT?
I have the following setup:
Internet ------ Firewall------(Pivat IP Range)---UC540------WLAN + DATA clients
Thanks for a suggestion
Lorenz
10-30-2012 02:28 PM
Hello Mr. Neher,
Thank you for your question.
In order to provide you an accurate and quick answer please try on the correct section of the forum for this devices "small business - Voice", You can move your post using the Actions Panel on the right.
Best regards
Diego Rodriguez
Cisco network engineer
10-30-2012 02:49 PM
Hi Lorenz,
I moved your post into the correct area.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
08-16-2013 10:00 PM
I have the same issue.
UC540-fxo, with latest 8.6.2 firmware, cca 3.2.2.
sg300-28p
I have the internet settings set as static.
I can ping 8.8.8.8 all fine.
But DNS info is not getting passed through DHCP.
And when I try to edit this DHCP pool information, I get this exact same error.
If I set dns servers manually in the network settings of the desktop, I do have "internet access".
Just spent last 2 hours trying to figure out what the problem is.
Will look at startup-config on sunday, will let you know if I get anywhere.
