Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
1052
Highlighted
Beginner
UC540 external IMAP for voicemail
Is it possible to setup a UC540 with external access to the email server
Everyone's tags (4)
7 REPLIES 7
Hall of Fame Master
Meaning what for example ?
Beginner
Re: UC540 external IMAP for voicemail
So that a user out side of the network with a cell phone can use imap to connect to the voice mail server.
Hall of Fame Master
For that, configure VPN so that remote users can access anything from anywhere.
Alternatively just forward the needed ports on then internet router, and users will only access what you configured for.
Please remember to rate useful posts clicking on the stars below..
Beginner
The uc540 is being used as the gateway and I wanted to try to avoid VPN because the office mainly operates out of terminals. Is this still possible?
Hall of Fame Master
As above
Participant
Hi Mike,
This is possible. Here is what you need to do.
In your LAN you need to setup an A record that points to CUE. Then on your firewall you need to open the IMAP port and point it to CUE. Setup an A record on your public DNS that points to your external address that is NAT'ing to CUE. Make sure the A records you create on the LAN and the public DNS are the same.
Let me know if you need any further assistance.
Mario Garcia
Rising star
Hi Mike,
The other method I often used which worked well for me, is create an IMAP account in the users outlook/exchange and then get the Smart Phone to talk to exchange, this way all your outside communications is done to the exchange and you can apply corporate policies to it
There is always more than one way to kick the can
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
