UC540 FXS port "CCA Hangs"
sudan_023
Beginner
Beginner
Dear all,
The port needs to be a user phone
I need to be able to set it up in a hunt group etc
When I go to users and extensions / users and phones the operation in progress sits there endlessly with operation in progress.
The end result I need is an extension that can be put on everyones phones as a PA button
I will actually connect a PA system with speakers to the analogue line.
please help with the CLI configuration.
1 ACCEPTED SOLUTION
Hi Sudan,
You will need to have the following in the config:
stcapp ccm-group 1
stcapp
and the following example configure the phone and the extension.
Use the mac address of port. You may find it using the "sh stcapp dev summ"  just exclude the first four symbols from device name. Then configure as any sccp phone.
dial-peer voice 1004 pots
service stcapp
port 0/0/0
ephone-dn  200  dual-line
number 1004 no-reg primary
label 1004
description fxs
name fxs fxs
ephone  20
device-security-mode none
mac-address xxxx.xxxx.xxxx
ephone-template 16
max-calls-per-button 2
username "fxs" password 123456
type anl
button  1:200
HTH,
Alex
*Please rate helpful posts
15 REPLIES 15
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
By default, UC500 configure FXS port to be ephone. So if you look at therunning  configuration or the default configuration file stored in flash, you will see the commands that are used to do that.
i configured this way but it didnt work.
voice-port 0/0/0
description PA
station-id name 0
station-id number 1004
destination-pattern 1004
port 0/0/0
is there any command to define "user phone" and assign that extension to hunt group.
Hi Sudan,
stcapp ccm-group 1
stcapp
service stcapp
port 0/0/0
label 1004
description fxs
name fxs fxs
ephone  20
ephone-template 16
type anl
button  1:200
HTH,
Alex
Hi Alexander
Thanks for your help i still have one confusion. where is this username and password is used?
ephone  20
ephone-template 16
type anl
button  1:200
Thank you
Hi Sudan,
This is to create user with the phone. It is needed for CCA otherwise you may not create it if you do not wish. You may use it this user to log in to ccme.html web GUI.
If the question has been resolved please mark it as answered so that others may benefit from this.
Best regards,
Alex
Hi Alex,
I have this problem and cannot shoot it from my side. i.e. Someone calls ext 1004. Analogue phone picks up. Caller hangs up. Analogue phone currently hears Beep.  Beep.  Beep. Beep, etc. Can we make this silent so it does have any tone when the other party hangs up?
Sudan
sudan_023
Beginner
Beginner
Hi Alex,
Sudan
Hi Sudan,
From what type of connection you are getting the calls to the FXS port? FXO, ISDN, SIP, SCCP or another FXS port?
Best regards,
Alex
Hi Alex,
I need silence on the line when the other party hangs up is because I have a box connected to the line that detects silence. It needs silence to disconnect the line after the other party hangs up. So the phone on ext 1004 needs to have no tone when other party hangs up.
Hope that makes sense
Best Regards,
Sudan
Hello Sudan,
I understand but if the call comes from FXO you may only decrease a bit the time it disconnects but you cannot remove the tones at all you may decrease them up to one or something like that. Actually the inbound call from FXO are disconnected by the UC.
This is why I am asking from where the calls are coming to the FXS.
Best regards,
Alex
Hello Alex,
thanks for your support. can you please provide me sample config that how can i decrease that sound.
Sudan
Hi Alex,
I actually need the same thing.
The call comes from another extension on the UC540. It dials the FXS port ok and call is established. The caller hangs up but the FXS does not drop the call automatically. The FXS port hears Beep, Beep, Beep for 60 seconds.
i have set the voice-port up as follows:
voice-port 0/0/0
cptone AU
timeouts call-disconnect 1
timeouts ringing infinity
timeouts wait-release 3
timeouts power-denial 2500
description PA
station-id name PA
station-id number 405
caller-id enable
The call-disconnect should should hangup after 1 second from my command but it doesn't seem to be working.
Any possible solutions would be greatly appreciated.
Hello Darren,
in your case if it is an analogue phone connected to the FXS port as a start I would remove the following:
with "no" in front and then shut no shut the port.
HTH,
Alex
Hi Alex,
Thanks for the quick response. I added those only to try to stop the ringing. So removing them won't fix the problem unfortunately.
If the "timeouts call-disconnect 1" doesn't disconnect the call where is the setting that will disconnect when the other party hangs up? Is there a global setting maybe that I'm missing somewhere?
Any other ideas?
D.
