Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
87
Highlighted
UC540 Help no incoming calls
I'm trying to configure my UC540 to work over SIP.  I have outbound calls working fine.  Inbound calls disconnect right away.  Here is the output from debug ccsip calls.
002691: Sep 8 07:14:34.760: //-1/25167B2F80FE/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x88A9F128
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : xxxxxxx
Called Number : xxxxxxx
Source IP Address (Sig ): 192.168.3.5
Destn SIP Req Addr:Port : xxx.xxx.xxx.xxx:0
Destn SIP Resp Addr:Port : xxx.xxx.xxx.xxx:5060
Destination Name : xxx.xxx.xxx.xxx
002692: Sep 8 07:14:34.760: //-1/25167B2F80FE/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 63
Disconnect Cause (SIP) : 500
002693: Sep 8 07:14:34.768: //-1/2517175780FF/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x88AAA508
Calling Number : xxxxxxxxxxx
Called Number : xxxxxxxxxx
002694: Sep 8 07:14:34.772: //-1/2517175780FF/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 47
002695: Sep 8 07:14:34.928: //-1/25301DE98100/SIP/Call/sipSPICallInfo:
002696: Sep 8 07:14:34.928: //-1/25301DE98100/SIP/Call/sipSPICallInfo:
002697: Sep 8 07:14:34.932: //-1/253156398101/SIP/Call/sipSPICallInfo:
002698: Sep 8 07:14:34.932: //-1/253156398101/SIP/Call/sipSPICallInfo:
Any help would be great.  Let know if you need more info.
